![]() | Home > Faults & Fixes > Roof Leak |
You'll probably find it's the roof drains that have got clogged up and caused the water to back up and drip down.
cliftonvilla Member Since: 14 Jul 2012 Location: Iraq & Wrexham UK Posts: 14 ![]() |
Thanks for the reply/suggestion I'll have the drain tubes blown out with compressed air and see how it goes.
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I think you need to thread something down them, not air
Okay thanks, will try that to.
If you use air and blow the drain tubes off, then you will have a problem In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
