Home > Faults & Fixes > Roof Leak |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
You'll probably find it's the roof drains that have got clogged up and caused the water to back up and drip down.
Thu May 16 2013 1:08pm |
cliftonvilla Member Since: 14 Jul 2012 Location: Iraq & Wrexham UK Posts: 14 |
Thanks for the reply/suggestion I'll have the drain tubes blown out with compressed air and see how it goes.
Fri May 17 2013 6:58am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
I think you need to thread something down them, not air
Fri May 17 2013 6:59am |
Okay thanks, will try that to.
Fri May 17 2013 7:30am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
If you use air and blow the drain tubes off, then you will have a problem In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri May 17 2013 7:59am |
