Home > General > Why can't Land Rover get it right?
Page 3 of 3 <123
mse
BigCat8810 wrote:
Cheney makes a good point, when you are busy it is a real pain in the aCensored to be tramping back and forth to dealers etc. When I was having issues last year with my previous vehicle, I wasted far too much time f Censored ing about.
I'd be even more livid if I had a new one which was causing such grief. As per the original post 'why can't they get it right'. It's not as if this is a brand new design, the RRS has been around since '05 so surely the current generation should have benefited from faults being ironed out etc.
300Tdi Defender was the most reliable LR product I ever owned, it was a '97 car with 120k on clock but never broke down! Just a shame it was so easy for some Censored Censored to steal it!
THe current range rover is nothing like the 05 version and thats the thing to consider, every significant MY change its almost like a new car
Dealers tend to let land rover down, in the UK its down to the dealers. Mike
2014 Facelift Discovery
Post #373376 Wed Feb 13 2013 5:34pm
ARHRRS
As Cheney and BigCat8810 say it is a real pain to keep returning the vehicle to the dealer, for it to come back with the same faults.
It makes sense for me to use Colliers as they are only 2 train stations away from work, but I have just had enough of them after my HST, so I have booked a collect and return with Guy Salmon Coventry to see if they are any better.
Post #373441 Thu Feb 14 2013 12:42am
BigCat8810
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
'THe current range rover is nothing like the 05 version and thats the thing to consider, every significant MY change its almost like a new car'
I can't provide evidence to suggest any different, but I would be amazed if the later RRS is complete 'a new car' & whilst it benefits from new engines, gearboxes, interior and cosmetic changes to the look of the vehicle, I would put money (not sure how much) on there being an awful lot of the same stuff in both models. I expect a lot of the electrical components, sensors etc are common to '05 and current models, in my humble opinion. If it was so radically different, then it is a surprise that so many of the faults highlighted by owners of the newer cars are similar to those of the earlier cars in regard to warning lights & multiple systems failures which prove so challenging to diagnose.
I recently parked my RRS next to an old P38 and the body panels are very similar indeed. Also as I understand it the RRS shares a lot of its DNA with the Disco. --------------------------------------------------------
RRS TDV8 Black/Black (Gone)
RRS TDV8 Stornaway (Gone)
RR Vogue TDV8 (Gone)
RRS 4.4V8 (Gone)
Defender 110 300tdi (Stolen, much missed)
RR Vogue V8 P38 (Gone)
LR 90 TD (Gone)
Post #373455 Thu Feb 14 2013 10:06am
Indeed so. The "muddy bits" of the RRS are just D3 bits. There are some detail differences of course but it's bascially a D3 with a pseudo-FFRR body on it.
It will be interesting to see how much of the new FFRR is shared by the new RRS and whether that also gets shared in to the D4's replacement.
Platform/component sharing is central to modern car manufacturing. Look at VAG - a Skoda will have the same parts as an Audi costing considerably more. 2012 SDV6 - it's missing a couple of cylinders
Post #373467 Thu Feb 14 2013 11:47am
fkarim
I heard the new RRS will be built on the new FFRR's chassis as opposed to the Disco's chassis. Not official, could be wrong.
Post #373472 Thu Feb 14 2013 11:59am
If thats the case then i'd guess they will be fitting the 4.4V8 engine as an option. Very Happy
Post #373477 Thu Feb 14 2013 12:24pm
fkarim
^^ Heard that too Ady. Hopefully we'll find out very soon what's true and what's just rumours.
Post #373478 Thu Feb 14 2013 12:33pm
mse
Ignoring the engine, gearbox and transmission are a serious part of the car.
Computers have been upgraded, several times, not just software - hardware, latterly to the current OS for the infotainment...but then the ECU's are regularly updated - which you hear about all the time, whether it be firmware because of a fault or as part of updates.
Then there is the internals - design principles the same yes - but things inside have changes...the clocks dash, removal of the gear stick.
Then lets look at the boot - not even a split piece any more...which the associated technology.
Thats before you get into component changes, updates modifications - tweaks to wiring, manufacturing improvement - slight changed styles or added in bits. Suspension and brake changes
All in there are loads of changes at key points making it very different and certainly in all the key places...or the critical important and complex places Exclamation Mike
Post #373510 Thu Feb 14 2013 4:38pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
What about the upper tailgate switch on my 05 RRS being a Ford Part Wink
My boss used to have an Aston Martin Vanquish, cracked a headlight, cost £1600 to replace. A side indicator failed later, cost to replace £1.40 (or similarly lowly priced)... it was a Ford part Rolling with laughter
"Roads ? Where we're going there are no roads." Back to the future.
Post #373515 Thu Feb 14 2013 5:28pm
I've seen a number of FoMoCo logos on bits in my MY08 RRS. I think something to do with the alarm is a Volvo item. 2012 SDV6 - it's missing a couple of cylinders
Post #373520 Thu Feb 14 2013 6:25pm
BigCat8810
Good Evening MSE,
I don't dispute the major differences between models, nor do I underestimate the impact of new engines, gearboxes etc. and indeed I aspire to own a newer model as and when my fledgling business allows the necessary budget. However, as someone with no technical qualifications, but a keen interest in ‘quality engineering’ I guess my question is when LR or any other manufacturer for that matter, launch a new model do they change components such as sensors etc. or do they reach into the company parts bin and grab what’s available?
I know when the L322 MY’05 model FFRR was launched, one of the major advances was a new wiring system, but was that the case with the 2nd generation RRS when they launched the MY ’10 model??
I would love to be wrong, but suspect much of the ‘infrastructure’ was similar to the early model, which would explain why some of the mysterious faults experienced by owners of the newer vehicle, are similar to that I experienced with my very own lemon! (fortunately my current example is gently restoring faith, long may it continue!).
Anyway, I’d be interested to know if the vehicles post MY ’10 use a different wiring / messaging system for faults etc., I suspect it’s the same old ‘bus’ system but as previously stated, very happy for someone to educate me? --------------------------------------------------------
RRS 4.4V8 (Gone)
LR 90 TD (Gone)
Post #373545 Thu Feb 14 2013 11:00pm
mse
Wiring looms change all the time, even in model years - principles are the same. They will also change because they have different things to add or deleted...so yes that does also change.
A quick example would be the trailer electrics - looms are differen 10 - 11MY 11My-12 and 13MY on - the former requiring fuses and extra bits the latter being plugs directly behind the bumper
Ive mentioned software, hardware (ECU) updates - they also modify locations of runs if there are identified issues.
A point always to make, if everyone on hear complained about the same thing and you times by 10% or 10 - it would still be a small fraction of the total number sold. Mike
Post #373606 Fri Feb 15 2013 5:12pm
Page 3 of 3 <123
