![]() | Home > General > Why can't Land Rover get it right? |
ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36 ![]() ![]() ![]() |
As Cheney and BigCat8810 say it is a real pain to keep returning the vehicle to the dealer, for it to come back with the same faults.
BigCat8810 Member Since: 20 Feb 2012 Location: Berkshire Posts: 132 ![]() ![]() ![]() |
'THe current range rover is nothing like the 05 version and thats the thing to consider, every significant MY change its almost like a new car'
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9024 ![]() ![]() ![]() |
Indeed so. The "muddy bits" of the RRS are just D3 bits. There are some detail differences of course but it's bascially a D3 with a pseudo-FFRR body on it. It will be interesting to see how much of the new FFRR is shared by the new RRS and whether that also gets shared in to the D4's replacement. Platform/component sharing is central to modern car manufacturing. Look at VAG - a Skoda will have the same parts as an Audi costing considerably more. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I heard the new RRS will be built on the new FFRR's chassis as opposed to the Disco's chassis. Not official, could be wrong. |
If thats the case then i'd guess they will be fitting the 4.4V8 engine as an option. |
^^ Heard that too Ady. Hopefully we'll find out very soon what's true and what's just rumours. |
Ignoring the engine, gearbox and transmission are a serious part of the car. Computers have been upgraded, several times, not just software - hardware, latterly to the current OS for the infotainment...but then the ECU's are regularly updated - which you hear about all the time, whether it be firmware because of a fault or as part of updates. Then there is the internals - design principles the same yes - but things inside have changes...the clocks dash, removal of the gear stick. Then lets look at the boot - not even a split piece any more...which the associated technology. Thats before you get into component changes, updates modifications - tweaks to wiring, manufacturing improvement - slight changed styles or added in bits. Suspension and brake changes All in there are loads of changes at key points making it very different and certainly in all the key places...or the critical important and complex places ![]() 2014 Facelift Discovery |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
What about the upper tailgate switch on my 05 RRS being a Ford Part ![]() My boss used to have an Aston Martin Vanquish, cracked a headlight, cost £1600 to replace. A side indicator failed later, cost to replace £1.40 (or similarly lowly priced)... it was a Ford part ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
I've seen a number of FoMoCo logos on bits in my MY08 RRS. I think something to do with the alarm is a Volvo item. 2012 SDV6 - it's missing a couple of cylinders
Good Evening MSE, I don't dispute the major differences between models, nor do I underestimate the impact of new engines, gearboxes etc. and indeed I aspire to own a newer model as and when my fledgling business allows the necessary budget. However, as someone with no technical qualifications, but a keen interest in ‘quality engineering’ I guess my question is when LR or any other manufacturer for that matter, launch a new model do they change components such as sensors etc. or do they reach into the company parts bin and grab what’s available? I know when the L322 MY’05 model FFRR was launched, one of the major advances was a new wiring system, but was that the case with the 2nd generation RRS when they launched the MY ’10 model?? I would love to be wrong, but suspect much of the ‘infrastructure’ was similar to the early model, which would explain why some of the mysterious faults experienced by owners of the newer vehicle, are similar to that I experienced with my very own lemon! (fortunately my current example is gently restoring faith, long may it continue!). Anyway, I’d be interested to know if the vehicles post MY ’10 use a different wiring / messaging system for faults etc., I suspect it’s the same old ‘bus’ system but as previously stated, very happy for someone to educate me? -------------------------------------------------------- RRS TDV8 Black/Black (Gone) RRS TDV8 Stornaway (Gone) RR Vogue TDV8 (Gone) RRS 4.4V8 (Gone) Defender 110 300tdi (Stolen, much missed) RR Vogue V8 P38 (Gone) LR 90 TD (Gone) |
Wiring looms change all the time, even in model years - principles are the same. They will also change because they have different things to add or deleted...so yes that does also change.
