Home > General > Ride Height |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
The IID should have stored the original settings on the first pairing with your RRS. This then enables you to restore factory settings when needed - is this not the case ? 16MY Estoril Blue SVR.............
Sun Feb 10 2013 8:26am |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 533 |
Already covered here:-
Sun Feb 10 2013 5:52pm |
KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61 |
Thanks but that's not the case because my ride height was already out of sync, not the factory setting when I used the IIDTool. |
Mon Feb 11 2013 7:44am |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
You need someone to measure the distance from arch to the alloy rim (what size alloy have you got?) so you can replicate it.
Mon Feb 11 2013 9:00am |
I have 22in rims
Mon Feb 11 2013 9:55am |
Hi,
Mon Feb 11 2013 12:42pm |
thanks a lot that's helpful |
Mon Feb 11 2013 3:54pm |
