Home > General > Ride Height
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Ride Height
Help needed
Does anyone know what's the correct ride height for a 2006 RRS?
I'm trying to calibrate my suspension using a IIDTool and want to know what's the original ride height of the car at normal "standard" ride height.
HELP PLEASE!!!
Post #372879 Sun Feb 10 2013 2:16am
PEACHY
The IID should have stored the original settings on the first pairing with your RRS. This then enables you to restore factory settings when needed - is this not the case ? Shocked 16MY Estoril Blue SVR.............
Post #372886 Sun Feb 10 2013 8:26am
scrumps
Already covered here:-
http://www.rrsport.co.uk/forum/topic25042....on+heighth
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #372951 Sun Feb 10 2013 5:52pm
KR1005
Thanks but that's not the case because my ride height was already out of sync, not the factory setting when I used the IIDTool.
Post #373000 Mon Feb 11 2013 7:44am
You need someone to measure the distance from arch to the alloy rim (what size alloy have you got?) so you can replicate it. Thumbs Up
Mines's not running at standard height so cannot help.. Thumbs Up RRS gone
Post #373006 Mon Feb 11 2013 9:00am
KR1005
I have 22in rims
can someone help measure it for me
Post #373011 Mon Feb 11 2013 9:55am
scrumps
As the previous thread I pointed out above staes "200mm from rim to arch for 20" wheels", I would reckon that 175mm from rim to arch for 22" wheels (i.e a 1" or 25mm change in radius) would fit the bill.
Post #373043 Mon Feb 11 2013 12:42pm
KR1005
thanks a lot that's helpful
Post #373093 Mon Feb 11 2013 3:54pm
