Home > Faults & Fixes > Rrs red suspension light on help ! |
Any RED warning means park safely and don't drive, seek dealer help. It will of logged fault code and a dealer or any indi with the correct diagnostic equipment will be able to identify the fault. |
Wed Jan 30 2013 8:52pm |
jvautos Member Since: 21 Nov 2012 Location: hampshire Posts: 28 |
I have got a 2 u codes out of it with my
Wed Jan 30 2013 9:02pm |
What are the codes Other members may know what they mean. |
Wed Jan 30 2013 9:09pm |
The code is U0434 ? Cheers |
Wed Jan 30 2013 9:56pm |
Are they the only codes you had? Most of the u codes are communications issues and that one is
Wed Jan 30 2013 9:59pm |
My auto data says that code
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 |
Invalid Data Received From Active Roll Control Module Other than that I have no idea Good luck, I'm sure someone else will be able to help out with more info...... |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
(Answered by Gerico - shows that at least two of us can use the search function!) |
Wed Jan 30 2013 10:00pm |
What do i do next im lost for ideas
Wed Jan 30 2013 10:01pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
mine has done this a couple off time but i just plug my snap on machine in and re set it . |
Wed Jan 30 2013 10:02pm |
It will not let me clear the codes and
Wed Jan 30 2013 10:04pm |
But I need to type faster....... |
Wed Jan 30 2013 10:29pm |
clear the codes then raise the suspension then lower it back to normal ride high and see if the lights go out, |
Thu Jan 31 2013 7:13am |
Why not? I know their nick name is stealers, but at least let them find out what the problem is and possibly give you a quote for the repair, that way you will know what the problem is without us lot guessing and it might just be cheaper that way. |
Thu Jan 31 2013 7:32am |
