Home > Faults & Fixes > Rrs red suspension light on help !
jvautos
Hi my rrs has a red suspension light on
It goes up and down fine but leans rely
Bad in corners and says suspension problem
When cornering with a red light any ideas cheers
Post #371623 Wed Jan 30 2013 8:44pm
Any RED warning means park safely and don't drive, seek dealer help. Big Cry It will of logged fault code and a dealer or any indi with the correct diagnostic equipment will be able to identify the fault. Thumbs Up
Post #371626 Wed Jan 30 2013 8:52pm
jvautos
I have got a 2 u codes out of it with my
Snapon scanner but they mean nothing
All it dose is roll in corners it goes up
And down fine ?
Post #371629 Wed Jan 30 2013 9:02pm
What are the codes Question Other members may know what they mean.
Post #371630 Wed Jan 30 2013 9:09pm
jvautos
The code is U0434 ? Cheers
Post #371646 Wed Jan 30 2013 9:56pm
Bodsy
Site Sponsor
Are they the only codes you had? Most of the u codes are communications issues and that one is
Invalid data received from dynamic response module Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371647 Wed Jan 30 2013 9:59pm
jvautos
My auto data says that code
Means invalid data received from
Active roll module . Dose this mean its the
Compressor being week ?
Post #371648 Wed Jan 30 2013 9:59pm
Gerico
Invalid Data Received From Active Roll Control Module
Shocked Other than that I have no idea Rolling Eyes
Good luck, I'm sure someone else will be able to help out with more info......
Post #371649 Wed Jan 30 2013 9:59pm
DrLex
Iceland
(Answered by Gerico - shows that at least two of us can use the search function!)
Post #371650 Wed Jan 30 2013 10:00pm
jvautos
What do i do next im lost for ideas
And do not want to take it to landrover
Post #371651 Wed Jan 30 2013 10:01pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
mine has done this a couple off time but i just plug my snap on machine in and re set it .
Post #371652 Wed Jan 30 2013 10:02pm
jvautos
It will not let me clear the codes and
When i can clear them the light just comes
Straight back on as i drive down the road
With bad body roll in corners . Im lost
HELP : )
Post #371653 Wed Jan 30 2013 10:04pm
Gerico
Thumbs Up But I need to type faster....... Wink
Post #371658 Wed Jan 30 2013 10:29pm
cossiedave
clear the codes then raise the suspension then lower it back to normal ride high and see if the lights go out,
Post #371675 Thu Jan 31 2013 7:13am
Why not? I know their nick name is stealers, but at least let them find out what the problem is and possibly give you a quote for the repair, that way you will know what the problem is without us lot guessing and it might just be cheaper that way. Wink
Post #371676 Thu Jan 31 2013 7:32am
