![]() | Home > Faults & Fixes > Rrs red suspension light on help ! |
Any RED warning means park safely and don't drive, seek dealer help. |
jvautos Member Since: 21 Nov 2012 Location: hampshire Posts: 28 ![]() ![]() |
I have got a 2 u codes out of it with my
What are the codes |
The code is U0434 ? Cheers |
Are they the only codes you had? Most of the u codes are communications issues and that one is
My auto data says that code
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 ![]() ![]() ![]() |
Invalid Data Received From Active Roll Control Module ![]() ![]() Good luck, I'm sure someone else will be able to help out with more info...... |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
(Answered by Gerico - shows that at least two of us can use the search function!) |
What do i do next im lost for ideas
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
mine has done this a couple off time but i just plug my snap on machine in and re set it . |
It will not let me clear the codes and
clear the codes then raise the suspension then lower it back to normal ride high and see if the lights go out, |
Why not? I know their nick name is stealers, but at least let them find out what the problem is and possibly give you a quote for the repair, that way you will know what the problem is without us lot guessing and it might just be cheaper that way. ![]() |
