Home > Technical > smokey engine
rottyexpress
smokey engine
S O S my rr sport oil coming out of the egr pipe and loads of diesel white smoke coming out from the rear pipes, any anwser please.
Post #367487 Sun Dec 23 2012 11:40am
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Might sound silly but you havn't overfilled the oil.
Supporting the London Air Ambulance with my Brothers
Post #367492 Sun Dec 23 2012 1:26pm
Texstar
Can you be more specific about the pipe oil is coming out of? Have you checked intercooler hoses for splits etc ?....if there is,you will no doubt see oil leaking out where the split is, are you loosing any coolant? does the vehicle perform ok? RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #367497 Sun Dec 23 2012 2:01pm
rottyexpress
had the headgasket done as i had a cracked rad and didnt realise got it running again now a tapping noise and white smoke coming out of the oil dip stick and oil filler cap, the other thing is there's alot of diesel smoke coming out of the rear tail pipes.
Post #367504 Sun Dec 23 2012 4:28pm
Disco_Mikey
Sounds like either the engine is FUBAR'd, or whoever done the head gasket has Censored it up
Post #367511 Sun Dec 23 2012 7:14pm
