![]() | Home > Technical > smokey engine |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Might sound silly but you havn't overfilled the oil. |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Can you be more specific about the pipe oil is coming out of? Have you checked intercooler hoses for splits etc ?....if there is,you will no doubt see oil leaking out where the split is, are you loosing any coolant? does the vehicle perform ok? RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
rottyexpress Member Since: 24 Nov 2012 Location: leicester Posts: 7 ![]() ![]() ![]() |
had the headgasket done as i had a cracked rad and didnt realise got it running again now a tapping noise and white smoke coming out of the oil dip stick and oil filler cap, the other thing is there's alot of diesel smoke coming out of the rear tail pipes. |
Sounds like either the engine is FUBAR'd, or whoever done the head gasket has |
