Home > In Car Electronics > Sast Nav DVD Player |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
put the seat as forward as possible, then access from behind iirc RRS gone
Fri Dec 21 2012 11:49am |
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 |
Do you have to unbolt it and move forwards? It has the retaining brackets on the side? |
Fri Dec 21 2012 12:01pm |
I've just gone out and looked
Fri Dec 21 2012 12:07pm |
Ill have another go, when I tried the cd hit that metal plate that the kick panel clips to. It dosent seem to move so couldnt work out how to get access to the cd. Thought it would be a crazy design otherwise. |
Fri Dec 21 2012 12:09pm |
was that with the seat moved forward?
Fri Dec 21 2012 12:13pm |
Simple, just lift the seat as high as possible and as far forward as possible, you will then be able to see ALL of the NAV unit In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Dec 21 2012 12:17pm |
Got it, thanks for the help. The plate slides forwards with the seat to give you the access needed. All taken care of now. |
Fri Dec 21 2012 12:57pm |
