![]() | Home > In Car Electronics > Sast Nav DVD Player |
put the seat as forward as possible, then access from behind iirc |
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 ![]() ![]() |
Do you have to unbolt it and move forwards? It has the retaining brackets on the side? |
I've just gone out and looked
Ill have another go, when I tried the cd hit that metal plate that the kick panel clips to. It dosent seem to move so couldnt work out how to get access to the cd. Thought it would be a crazy design otherwise. |
was that with the seat moved forward?
Simple, just lift the seat as high as possible and as far forward as possible, you will then be able to see ALL of the NAV unit In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Got it, thanks for the help. The plate slides forwards with the seat to give you the access needed. All taken care of now. |
