Home > In Car Electronics > Sast Nav DVD Player
jdgeary1
2006 Range Rover Sport TDV6 HSE Sumatra Black
Sast Nav DVD Player
I have an updated disc for my Sat Nav, which is located under the passenger front chair. Question, how do I get the CD out of it. Its mounted forwards. I took the front kick plate off, the plastic one, and there is a metal panel riveted in place so I cannot actually eject the cd. Why the heck isnt it mounted backwards for ease of access?
Any ideas?
Post #367292 Fri Dec 21 2012 11:04am
put the seat as forward as possible, then access from behind iirc Thumbs Up RRS gone
Post #367297 Fri Dec 21 2012 11:49am
jdgeary1
Do you have to unbolt it and move forwards? It has the retaining brackets on the side?
Post #367303 Fri Dec 21 2012 12:01pm
I've just gone out and looked
take the kick plate off (plastic)
then move the seat forward 10"
make sure the lock slider is set to unlock
then there is plenty of access space to get the old disk out and the new one in (from the front not back)
Thumbs Up RRS gone
Post #367305 Fri Dec 21 2012 12:07pm
jdgeary1
Ill have another go, when I tried the cd hit that metal plate that the kick panel clips to. It dosent seem to move so couldnt work out how to get access to the cd. Thought it would be a crazy design otherwise.
Post #367307 Fri Dec 21 2012 12:09pm
was that with the seat moved forward?
Can the seat be slid any further forward maybe RRS gone
Post #367308 Fri Dec 21 2012 12:13pm
SRE
Spain
Simple, just lift the seat as high as possible and as far forward as possible, you will then be able to see ALL of the NAV unit In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #367310 Fri Dec 21 2012 12:17pm
jdgeary1
Got it, thanks for the help. The plate slides forwards with the seat to give you the access needed. All taken care of now.
Post #367311 Fri Dec 21 2012 12:57pm
