Home > General > How many maps does the BAS interface hold |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
yep.. sounds like the license has thrown a wobbly.
Wed Dec 19 2012 3:57pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
If you went to dealer with the standard map loaded then it should not be a big deal. What happened is that the dealer loaded an update to your car. Now the BAS interface sees a different map ID and is unable to load the performance map. You basically did all is necessary. - Delete the data from the interface. - reset the unit to Land Rover/RRS 2.7 - read the new map on the car - send the new file to Pete - he will create a new performance map based on that and email it back to you. - load the new map on the unit then load it on your car. Done. This is why it is important to always reload the standard map everytime you take the car to the dealer for servicing or for a problem. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Wed Dec 19 2012 4:13pm |
ALL SORTED....
Thu Dec 20 2012 10:24am |
Excellent, glad you got it sorted. Thumbs up for Pete |
Thu Dec 20 2012 1:28pm |
