![]() | Home > General > How many maps does the BAS interface hold |
yep.. sounds like the license has thrown a wobbly.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
If you went to dealer with the standard map loaded then it should not be a big deal. What happened is that the dealer loaded an update to your car. Now the BAS interface sees a different map ID and is unable to load the performance map. You basically did all is necessary. - Delete the data from the interface. - reset the unit to Land Rover/RRS 2.7 - read the new map on the car - send the new file to Pete - he will create a new performance map based on that and email it back to you. - load the new map on the unit then load it on your car. Done. This is why it is important to always reload the standard map everytime you take the car to the dealer for servicing or for a problem. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
ALL SORTED.... |
Excellent, glad you got it sorted. Thumbs up for Pete |
