Home > Maintenance & Modifications > Low Coolant Message
Abs1
2007 Range Rover Sport TDV6 HSE Java Black
Low Coolant Message
Hi, this is my first post so be easy on me! Smile
I have a 2007 RRS 2.7 d and the low coolant mesage has flashed on a couple of times now. It happened for the first time last week but then didn't show again till now. I'm taking the car in for a service at the dealers next Friday and didn't want to mix coolants could help it, so I wanted to wait. I rang the dealers and they said that if it's not leaking it should have enough in there to last till next Friday.
I've checked and it's doesn't seem to be leaking and does have some coolant in it. I'm told that I could add a cup of water to it and that should see me through, is that right?
Post #365543 Wed Dec 05 2012 2:17pm
Welcome Smile
Seems your not alone and it's probably the bottle or sensor.
Have a look at this thread here Thumbs Up ON THE WAY: BMW F21 M140i
Post #365544 Wed Dec 05 2012 2:20pm
Abs1
Thank you Beancounter_74 Smile
Although I'm not sure if the senor has gone or not. The coolant in the tank looks to be just under / on the line of the min boarder.
One thing that is strange though is that when I checked there is coolant at the top of the bottle but it doesn't appear to have filtered down it looks stuck there. Does anyone know if that means anything?
Post #365548 Wed Dec 05 2012 3:27pm
Sorry, I'm the last person to talk about 'technical' things, but hopefully someone will jump in here and answer for you.
Seems that the earlier models had a fault with the coolant bottles anyway, so could be worth sorting out for your own piece of mind Thumbs Up ON THE WAY: BMW F21 M140i
Post #365551 Wed Dec 05 2012 3:55pm
Sirwacko
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
I have exactly the same problem with mine. The coolant level was low and looked like some had congealed at the top of the reservoir. It's in being checked as I type ill let you know Smile RRS Dynamic
Post #366984 Tue Dec 18 2012 9:43am
ELD70
The floating foam ball sensor becomes porous and starts to sink causing false readings.
Post #367106 Wed Dec 19 2012 3:27pm
