![]() | Home > Maintenance & Modifications > Low Coolant Message |
Welcome |
Abs1 Member Since: 27 Sep 2012 Location: East Midlands Posts: 4 ![]() ![]() |
Thank you Beancounter_74 |
Sorry, I'm the last person to talk about 'technical' things, but hopefully someone will jump in here and answer for you.
Sirwacko Member Since: 22 Mar 2012 Location: Near Blackpool Posts: 74 ![]() ![]() ![]() |
I have exactly the same problem with mine. The coolant level was low and looked like some had congealed at the top of the reservoir. It's in being checked as I type ill let you know |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
The floating foam ball sensor becomes porous and starts to sink causing false readings. |
