Home > Technical > Knock when i press the brake pedal quickly |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Could be a number of things...
Wed Nov 21 2012 10:55am |
You don't have a rogue golf ball rolling about the car do you.......I joke, but was found to be the problem in my fathers car many moons ago ON THE WAY: BMW F21 M140i
Wed Nov 21 2012 10:58am |
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 |
I hear a knocking sound from the rear of the car when I go over potholes but the noise comes from the front of the car, Does nobody else's do this then? Its not a land rover 'charcteristic'! is it?
Wed Nov 21 2012 11:13am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4408 |
Front lower suspension arm bushes and rear anti roll bar bushes |
Wed Nov 21 2012 12:50pm |
Thanks Mikey,
Wed Nov 21 2012 1:01pm |
Most probably the bushes but I've known pads to move around in the past, hence asking when brakes were done.
Wed Nov 21 2012 1:34pm |
A good garage will |
Wed Nov 21 2012 3:15pm |
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 |
As Disco Mikey said.
Wed Nov 21 2012 10:10pm |
Well 9 hours on and my lower suspension nearside is still not off the car!
Thu Nov 22 2012 8:23pm |
Can you shorten the thread on the ball joint? The screw type splitters are about 1cm too small so chop a bit off the thread.
Thu Nov 22 2012 9:09pm |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
yes, i have this knock too, all new= all smooth |
Thu Nov 22 2012 9:28pm |
I have shortened the thread but the screw type I have won't go over the knuckle.
Thu Nov 22 2012 10:11pm |
Just an update:
Fri Nov 23 2012 11:12pm |
