Home > Technical > Knock when i press the brake pedal quickly
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Sorry to hear you had so much trouble with it Stefan Sad I'm hoping my driver side arm is as trouble free as my passenger one was Confused
Anyway - well done on doing it yourself, you've saved yourself about £450 Thumbs Up
Post #364280 Sat Nov 24 2012 12:39am
Stefan.lajszczuk
United Kingdom 2006 Range Rover Sport SDV6 SE Rimini Red
Thanks.
I've not even driven it yet since replacing the arm, it appears that the rubber inside the bush had sheared within itself so fingers crossed when I now brake on Monday, I won't get that knocking sound
Post #364283 Sat Nov 24 2012 1:18am
kav1187
Well I've only managed to do my passenger side so far as I don't have anywhere with shelter to work on the car so rely on dry days. Even though I was getting knocking on both sides before, it seems to have stopped completely after having just changed the one side.
I'm looking forward to doing the driver's side this weekend. Hopefully it'll make the car handle a bit better too.
Post #364284 Sat Nov 24 2012 1:46am
Scotty99
England 2008 Range Rover Sport TDV6 SE Stornoway Grey
kav1187 wrote:
Could be a number of things...
Do you hear any knocking sounds when you drive over potholes? Do you hear a click if you apply brakes when reversing? Is there any play on your steering wheel? When were the brake pads last changed? How long has this been a problem?
Have you ever had the anti roll bar bushes changed?
What would the problem be if you got a click when applying the brake while reversing, I have this on the offside front on my 2008 SE TDV6.
Post #485269 Wed Jan 20 2016 11:05am
