Home > Maintenance & Modifications > Autobiography exhaust tips for non PDF exhaust help!? |
Tim, the exhausts changed late 2010 to straight tailpipes, i'm sure if you just cut off the bit that is pointing downwards you should be fine, but i would place the exhaust tip along side your exhaust pipe first just to see if it is still going to be long enough to attach the A/B tip without it been too short. |
Thu Oct 25 2012 6:53am |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Be aware the older cars had downward firing exhausts for a reason RRS gone
Thu Oct 25 2012 10:21am |
timmymagic46 Member Since: 03 Oct 2012 Location: London Posts: 14 |
Interesting as I assumed all 2010 onwards facelift cars had the new exhaust... My speck sheet even says it is a PDF car! Tim Boler |
Thu Oct 25 2012 7:18pm |
Do you mean DPF |
Thu Oct 25 2012 7:57pm |
Yeah, that's he one Tim Boler |
Thu Oct 25 2012 7:59pm |
Sorry my mistake I thought you were fitting new exhaust tips to a pre-facelift RRS gone
Fri Oct 26 2012 7:55am |
its not uncommon for some early cars to carry some late spec kit - it could be your exhaust was such a left over item...or the wrong one fitted by someone else.
Fri Oct 26 2012 8:40am |
