Home > Maintenance & Modifications > Autobiography exhaust tips for non PDF exhaust help!?
timmymagic46
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi everyone.
I recently bought some 2010 oem land rover exhaust tips for my 2010 10 plate sport tdv6.
I went to go and fit them and realised the exhausts actually point downwards - all info I read stated after 2010 are straight pipes. The tips I now have don't fit,,
Does anybody know what ISP I need, if my car has the wrong exhaust and basically any ideas?!
Do I need to do any cutting? I have the autobiography rear bumper ready to fit as well but now the exhausts tips are giving me bother I am unsure what to do....
Any help greatly appreciated
Thanks
Tim Tim Boler
Post #360806 Wed Oct 24 2012 9:37pm
Tim, the exhausts changed late 2010 to straight tailpipes, i'm sure if you just cut off the bit that is pointing downwards you should be fine, but i would place the exhaust tip along side your exhaust pipe first just to see if it is still going to be long enough to attach the A/B tip without it been too short.
Post #360831 Thu Oct 25 2012 6:53am
Be aware the older cars had downward firing exhausts for a reason Wink Laughing RRS gone
Post #360857 Thu Oct 25 2012 10:21am
timmymagic46
Interesting as I assumed all 2010 onwards facelift cars had the new exhaust... My speck sheet even says it is a PDF car! Tim Boler
Post #360904 Thu Oct 25 2012 7:18pm
Do you mean DPF Question
Post #360912 Thu Oct 25 2012 7:57pm
timmymagic46
Yeah, that's he one Smile Tim Boler
Post #360913 Thu Oct 25 2012 7:59pm
Sorry my mistake I thought you were fitting new exhaust tips to a pre-facelift Embarassed RRS gone
Post #360944 Fri Oct 26 2012 7:55am
mse
its not uncommon for some early cars to carry some late spec kit - it could be your exhaust was such a left over item...or the wrong one fitted by someone else.
There is part number stamped on one of the silencers if you wanted to check Mike
2014 Facelift Discovery
Post #360948 Fri Oct 26 2012 8:40am
