Home > General > 2012 sport accelerator issues, anyone help?
A throttle sensor error will trigger limp home mode (virtually no power whatever throttle you select)
Are you not getting a limp mode error on the dash?
As far as I'm aware, there are 2 sensors, one counts "up" and the other counts "down". The ecu compares both values and applies the correct amount of throttle accordingly, if the ups and downs do not match, you will IMMEDIATLY get limp mode (safety measure) only cleared by stopping the car for a length of time. RRS gone
Post #355442 Mon Sep 03 2012 6:22pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
next time it does it, have a glance at the water temperature gauge too ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #355459 Mon Sep 03 2012 7:47pm
alfidog
Wales 2012 Range Rover Sport SDV6 HSE Bonatti Grey
No limp home mode, I used to get that in my last one, "safe mode".
I'll check the water temp, why would this be a factor? Long suffering Land Rover owner
Post #355465 Mon Sep 03 2012 8:56pm
rrsboy
it also causes limp home.. if ECU thinks engine is overheating, it will cut the power to protect it from damage.. I experienced first hand several times going up hill.. turned out a lead to the fan was not connected, meaning the fan wasn't working
there is also a recall for fan wires that were plumbed in back-to-front meaning the fan rotated the wrong way ============
Post #355475 Mon Sep 03 2012 9:13pm
alfidog
Strange thing about this problem, is there is no fault showing on the dash, it only shows up when the technician plugs his laptop in. Then it shows the car traveling along, and then the engine goes to idle. Long suffering Land Rover owner
Post #355503 Tue Sep 04 2012 9:03am
mse
Ive also see mud and similar clogging airflow over radiators triggering overheating and limp home mode - not on a sport though, but its possible. Mike
2014 Facelift Discovery
Post #355517 Tue Sep 04 2012 11:53am
rrsboy
some Sports do get clogged Rolling with laughter
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ============
Post #355519 Tue Sep 04 2012 11:59am
mse
i more meant ive never seen the clogging fault on a sport - other products yes (defender did it for a spell) but not the disco or sport Thumbs Up
Only show me photos when the pressure washer cant remove it after 3 or 4 washes! Razz Mike
Post #355522 Tue Sep 04 2012 12:20pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
[quote="mse"Ive also see mud and similar clogging airflow over radiators triggering overheating and limp home mode - not on a sport though, but its possible.[/quote]
Had the same thought, I recall the puma defender not liking Salisbury Plain mud. No indication of overheating on the needle, but instant limp home on the third lane of the motorway due to overheating Shocked Shocked Shocked
"Roads ? Where we're going there are no roads." Back to the future.
Post #355524 Tue Sep 04 2012 12:29pm
mse
You are correct, although I cant fully remember what the issue was as i dont think it was clear cut eg: this MY + Clog = Fault
Anyway, the results were similar...and as mentioned not indicated as you would expect. Mike
Post #355526 Tue Sep 04 2012 12:32pm
alfidog
Land Rover eventually found the fault. It was "the car getting stuck in 3rd gear, and occasionally 6 or 7.
Now sorted, new vehicle getting delivered end of November, with a mileage contribution from me! Long suffering Land Rover owner
Post #357354 Thu Sep 20 2012 9:51pm
Did you end up rejecting the vehicle or have you just ordered another new one Question
Post #357370 Fri Sep 21 2012 6:39am
alfidog
Rejected it. Long suffering Land Rover owner
Post #357373 Fri Sep 21 2012 6:58am
