Home > General > 2012 sport accelerator issues, anyone help? |
A throttle sensor error will trigger limp home mode (virtually no power whatever throttle you select)
Mon Sep 03 2012 6:22pm |
alfidog Member Since: 01 Sep 2012 Location: Denbighshire Posts: 9 |
No limp home mode, I used to get that in my last one, "safe mode".
Mon Sep 03 2012 8:56pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
it also causes limp home.. if ECU thinks engine is overheating, it will cut the power to protect it from damage.. I experienced first hand several times going up hill.. turned out a lead to the fan was not connected, meaning the fan wasn't working
Mon Sep 03 2012 9:13pm |
Strange thing about this problem, is there is no fault showing on the dash, it only shows up when the technician plugs his laptop in. Then it shows the car traveling along, and then the engine goes to idle. Long suffering Land Rover owner |
Tue Sep 04 2012 9:03am |
Ive also see mud and similar clogging airflow over radiators triggering overheating and limp home mode - not on a sport though, but its possible. Mike 2014 Facelift Discovery |
Tue Sep 04 2012 11:53am |
some Sports do get clogged
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Tue Sep 04 2012 11:59am |
i more meant ive never seen the clogging fault on a sport - other products yes (defender did it for a spell) but not the disco or sport
Tue Sep 04 2012 12:20pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
[quote="mse"Ive also see mud and similar clogging airflow over radiators triggering overheating and limp home mode - not on a sport though, but its possible.[/quote]
Tue Sep 04 2012 12:29pm |
You are correct, although I cant fully remember what the issue was as i dont think it was clear cut eg: this MY + Clog = Fault
Tue Sep 04 2012 12:32pm |
Land Rover eventually found the fault. It was "the car getting stuck in 3rd gear, and occasionally 6 or 7.
Thu Sep 20 2012 9:51pm |
Did you end up rejecting the vehicle or have you just ordered another new one |
Fri Sep 21 2012 6:39am |
Rejected it. Long suffering Land Rover owner |
Fri Sep 21 2012 6:58am |
