Home > General > Suspension light on!!!
bulletooth
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Slick you are the man ! was just about to book my 2006 HSE in to have a whole new compressor unit fitted as im having exactly the same problems as you but now im going to try change the dryer first and ill let you know how i get on Thumbs Up
Post #355107 Thu Aug 30 2012 11:34am
slick17
2006 Range Rover Sport Supercharged Java Black
No probs bulletooth.
Good Luck! S/C 06 Black
Post #355223 Fri Aug 31 2012 6:23pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
Hey Mrfrog, I have had the same problem with the access hieght being denied and the system adviseing to remove obstruction from underside, was the compressor exhaust valve not serviceable or did you decide to fit a new unit regardless, any advise is appreciated.
Post #355234 Fri Aug 31 2012 9:43pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
It started really playing up + air suspension fault warnings on the Wednesday prior to a week end away during which we'd be covering a few hundred miles. Had to be fixed friday lunchtime, so I bit the bullet and ordered a compressor on thu morning, got it in the afternoon and was ready on friday for the trip.
I might have investigated more had I had the time, but in this case, I had to take the shortest time to fix.
From what I saw on microcat, there was no serviceable part that I could see.
"Roads ? Where we're going there are no roads." Back to the future.
Post #355245 Fri Aug 31 2012 11:33pm
factoryfil
Thanks for the info, haven't got any warning lights as yet, just no access hieght, maybe time for a new compreesor.
Post #355309 Sat Sep 01 2012 11:04pm
slick17
Short term fix for dryer/compressor/suspension problem!!!!
Guys,
Had the opportunity to open the dryer that was removed from my car. Found that there was a filter either end with drying beads filling the space between them.
Now on my dryer the filters were clogged...causing the fault. It is entirely possible to clean the filters and replace the unit without the need to buy a new one. The drying beads looked intact apart from the 5% that had disintegrated and clogged the filters.
How long this fix will last is anybody's guess...Iam just putting it out there in case someone wants to save money on buying a new dryer...why buy a replacement if the original just needs cleaning out?
Just a thought!!!!
cheers S/C 06 Black
Post #355321 Sun Sep 02 2012 7:16am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
can you post some pics?Its always useful to see what parts look like.
Post #355325 Sun Sep 02 2012 9:15am
slick17
Sorry mrfixit....did not have the presence of mind to take any pics at the time. Luckily, I still have the dryer and so will try and put up a couple of pics in the next day or two.
cheers S/C 06 Black
Post #355327 Sun Sep 02 2012 9:44am
mrfrog
I won't steal slick17's thunder with pictures, however I took my drier apart today out of curiosity, below are my findings:
-Had to drill out the screw (Phillips) that holds the drier to the compressor's body.
-Remaining pipe on drier wouldn't come off, had to cut it.
-The drier twists on the compressor's input and should pull off gracefully. Mine didn't, had to persuade it off and an o-ring suffered as a result. Pretty sure it would go back on though.
-Three of the six drier screws were too rusty to come off (torx), had to use pliers on them.
Finally opened the drier and after removing the spring and some dust, the rest wouldn't come out nicely. So I used a little more prodding and pulling on the internals, luckily over a bin... and the drier emptied itself, much dust and beads.
Based on this experience, I wouldn't attempt to service one unless it looks relatively new on the outside, mine came off my 05 RRS, so 7 years old unless replaced since. A new o-ring would likely to be needed too.
Post #355376 Sun Sep 02 2012 6:24pm
slick17
Mrfixit,
No problem....we are all here to help each other. I probably know the least about cars as compared to some of the other members....based on the information I have seen on this and other forums.
Although i asked for help on this particular topic and had pretty quick response to it...I felt I should at least try and do a little research myself....and hey presto...the information is all out there...god bless the internet Very Happy
Sounds like your dryer was on its last legs! Mine was pretty easy to open and actually looked fairly new. Once opened the filters were clogged but 90% odd of the beads were intact...mine is an 06.....maybe it has been replaced before!!!
Appreciate your input... Thumbs Up
cheers S/C 06 Black
Post #355384 Sun Sep 02 2012 8:28pm
mrfrog
Hey slick17, I'm not mrFixit but mrFrog Wink Ner Ner Thumbs Up
Post #355385 Sun Sep 02 2012 8:34pm
slick17
Sorry MRfrog....brain is obviously not in gear tonight.... Big Cry Thumbs Up S/C 06 Black
Post #355387 Sun Sep 02 2012 8:42pm
lars@haverud.se
Sweden
control valve overlay harness
I have problem with the suspension system, switch to a new compressor. And now their is still problems to high and low the car. I had some discussions with the local LR repairman. I need to install a new front suspension control valve overlay harness-Range Rover Sport (Causal part YNN500472). Where can I buy that part to best price?
Post #360225 Sat Oct 20 2012 1:17pm
