Home > General > Unwanted resonance sound at 2000 RPM's revs at 75-80 km/h
moe696
Norway 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
I own a MY07 RRS 2,7 TDV6. The last year I have experienced a strange resonance sound at approx 2000 rpm's / 80 km/h. Often at a small load (ex uphill).
My local Land Rover dealer have had their fair share of ideas, and have tried the following with no result:
-replacement of front and rear diff's
-fuel filter
-replacement of main drive shaft
Their latest theory is that it may be caused by vibrations in the exhaust system.
Have somebody else experienced this sound (with a very small vibration)
Regards
Post #349954 Fri Jul 06 2012 12:13pm
Could be tyre related - some tyres can be a bit noisy at certain speeds. If there is a vibration too then that might point to a balance issue or a slightly buckled wheel rim. Might be worth having the alignment checked too. 2012 SDV6 - it's missing a couple of cylinders
Post #349984 Fri Jul 06 2012 5:30pm
moe696
I have same problem on my winter tires, so I guess this rules out tires as a problem.
Thanks for the suggestion
Regards Eirik
Post #350712 Sun Jul 15 2012 10:26am
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi Moe. When you get the noise is it while accelerating? I get a noise every now and again if I lift foot off accelerator and back on again it goes. Just wondered if it was the same?? Its not loud its only me that knows its there.
Supporting the London Air Ambulance with my Brothers
Post #350713 Sun Jul 15 2012 10:34am
