Home > General > Unwanted resonance sound at 2000 RPM's revs at 75-80 km/h
moe696
Norway 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
I own a MY07 RRS 2,7 TDV6. The last year I have experienced a strange resonance sound at approx 2000 rpm's / 80 km/h. Often at a small load (ex uphill).
My local Land Rover dealer have had their fair share of ideas, and have tried the following with no result:
-replacement of front and rear diff's
-fuel filter
-replacement of main drive shaft
Their latest theory is that it may be caused by vibrations in the exhaust system.
Have somebody else experienced this sound (with a very small vibration)
Regards
Post #349954 Fri Jul 06 2012 11:13am
Could be tyre related - some tyres can be a bit noisy at certain speeds. If there is a vibration too then that might point to a balance issue or a slightly buckled wheel rim. Might be worth having the alignment checked too. 2012 SDV6 - it's missing a couple of cylinders
Post #349984 Fri Jul 06 2012 4:30pm
moe696
I have same problem on my winter tires, so I guess this rules out tires as a problem.
Thanks for the suggestion
Regards Eirik
Post #350712 Sun Jul 15 2012 9:26am
panda
Hi Moe. When you get the noise is it while accelerating? I get a noise every now and again if I lift foot off accelerator and back on again it goes. Just wondered if it was the same?? Its not loud its only me that knows its there.
Post #350713 Sun Jul 15 2012 9:34am
