Home > Technical > Parkbrake warning light - Question
Bobs_buggy
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
I've just noticed that the red parkbrake light stays illuminated for 3 minutes after the ignition is switched off, even if you get out and lock the door. I can't remember seeing this before (I only picked my car up Friday). I don't get any warning messages, but I can't find any reference to it in the handbook, it just says that if the red parkbrake warning light flashes, take it to the dealers to get it sorted.
Is this normal?
Many thanks.
Bob. RRS 4.2 S/C. Zermatt. Tints. Stormers. 150+ paint defects, wonkey bonnet, scratches, detached doorseal. suspension faults. To sum it up, a �60k pile of cr4p!
Post #36152 Mon May 29 2006 5:21pm
Cliff H
Totaly normal, D3's do it as well.
Did not notice it on mine for a few days, had the same fault thoughts as you Wink
Post #36158 Mon May 29 2006 6:08pm
Bobs_buggy
Ah, thanks Cliff. Panic over, I can calm down now.
Post #36160 Mon May 29 2006 7:14pm
bigdwarf
India 2006 Range Rover Sport TDV6 HSE Java Black
Mine does so sporadically, so haven't bothered to get it redressed. Put it down to annoying-but-livable with gremlins. Rolling Eyes RRS 2.7TDV6 HSE Java Black, Sun Roof, Tasmod Sills
Post #36164 Mon May 29 2006 8:09pm
Slimer
It's normal, shows the system is still 'awake'. If you ever need to disconnect the battery for some reason or other make sure you wait for that light to go out before you do.
In a similar vain you may also notice if you unlock the car but don't put the key in the ignition before locking it again that the satnav screen stays on for ages too
Post #36166 Mon May 29 2006 8:49pm
Bobs_buggy
Thanks for the advice Slimer, I'll look out for that one..
Post #36170 Mon May 29 2006 10:02pm
