![]() | Home > Technical > Parkbrake warning light - Question |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
Totaly normal, D3's do it as well.
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 ![]() ![]() ![]() |
Ah, thanks Cliff. Panic over, I can calm down now.
bigdwarf Member Since: 12 Nov 2005 Location: Luxembourg Posts: 31 ![]() ![]() ![]() |
Mine does so sporadically, so haven't bothered to get it redressed. Put it down to annoying-but-livable with gremlins. |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
It's normal, shows the system is still 'awake'. If you ever need to disconnect the battery for some reason or other make sure you wait for that light to go out before you do.
Thanks for the advice Slimer, I'll look out for that one..
