Home > Technical > Parkbrake warning light - Question |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
Totaly normal, D3's do it as well.
Mon May 29 2006 6:08pm |
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 |
Ah, thanks Cliff. Panic over, I can calm down now.
Mon May 29 2006 7:14pm |
bigdwarf Member Since: 12 Nov 2005 Location: Luxembourg Posts: 31 |
Mine does so sporadically, so haven't bothered to get it redressed. Put it down to annoying-but-livable with gremlins. RRS 2.7TDV6 HSE Java Black, Sun Roof, Tasmod Sills |
Mon May 29 2006 8:09pm |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 |
It's normal, shows the system is still 'awake'. If you ever need to disconnect the battery for some reason or other make sure you wait for that light to go out before you do.
Mon May 29 2006 8:49pm |
Thanks for the advice Slimer, I'll look out for that one..
Mon May 29 2006 10:02pm |
