![]() | Home > General > Starting to look at RR Sports - what to look/listen for? |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 ![]() ![]() ![]() |
Hi Mike,
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks oxford_boy! I know it's a lot of questions, but may as well get them all out there!
Thanks ![]() - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
From memory, there was an issue with earlier RRS and large wheels (20 inch and more). There was a redesign on the steering rack to add a damper. Not sure whether there was a recall on this or just a "fit it if the punter complains". I think this was fitted as standard from MY2007 onwards.
OK, thanks for the hints and tips! I'm actively trying to avoid cars with large wheels, as I need 18" or maximum 19" wheels so I can get suitable A/T tyres for Morocco.
The locking rear diff (e-diff) was an option on the RRS. Still is I believe. Not many have it fitted though so far as I know. The G4 had it as standard I think. Not sure if any others have it as standard e.g. S/C. Someone will know though.
Not sure whether the terrain you will be encountering in Morocco would be this but the snow and ice terrain setting locks the rear diff I believe? I did quite a lot of research into snow chain use (which you may not need) and that was one of the offshoot findings.
Snow and ice will lock the centre diff as required by the traction available. It's open until required to be locked. The rear diff is always open unless the optional e-diff is specified for the rear.
Sounds like my chances of finding one with the locking rear 'e-diff' are slim - is there any way of telling if the car has one from inside the car?
Both look tidy examples, the silver one will be due a cambelt change anytime soon if it hasn't already been done approx £8-900 from a main dealer, the blue one looks a lot better imo as it is an HSE and for me thats the one i would choose due the the subtle changes its had, the blue one will require the cambelt change next year (7 years old or 105000 miles) |
Thanks Ady - that's the sort of invaluable advice I need!
I prefer the Blue too, it has and looks much better.
What aftermarket modifications? Only thing is 2010 rear lights + S/C grilles, and I doubt I would even mention them as they are just LR lights - in fact, I'd happily put the originals back on to be honest! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Ok, maybe some of the options came with the vehicle from new, I doubt it in a few of the cases but the addition of a Supercharged grille and vents to a TDV6 changes the vehicles appearance and your insurers will quibble that.
