Home > Technical > AIR SUSPENSION FAULT REAR CROSS LINK VALVE
grumans
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
Hi, I have an 05 SC first edition and it has recently developed an EAS fault C1A38 rear cross link valve. The car is in fault mode and although having fit a new rear EAS valve block (incorporating the cross link valve) it is no different. Can anyone tell me if if they have had this before and should a reset of the fault fix me up ? GRUMANS
Post #328640 Wed Jan 18 2012 9:36pm
grumans
Update today....had the fault cleared and it is still showing the cross link valve fault despite having fitted a new one so I need to investigate further...any ideas where to start gratefully received....Grumans
Post #328741 Thu Jan 19 2012 2:01pm
rangehelper
Russia
Look an electric socket behind a back left wheel.
Post #329364 Tue Jan 24 2012 8:43pm
grumans
Hi, thanks for that. I've managed to sort it. Turns out the drivers side footwells (front and rear) were full of water and the loom submerged causing a short to ground, fantastic these Range Rovers !
Post #329383 Tue Jan 24 2012 10:04pm
