![]() | Home > Technical > AIR SUSPENSION FAULT REAR CROSS LINK VALVE |
grumans Member Since: 18 Jan 2012 Location: Lancashire Posts: 7 ![]() ![]() ![]() |
Update today....had the fault cleared and it is still showing the cross link valve fault despite having fitted a new one so I need to investigate further...any ideas where to start gratefully received....Grumans |
rangehelper Member Since: 17 Nov 2011 Location: Moscow Posts: 4 ![]() ![]() |
Look an electric socket behind a back left wheel. |
Hi, thanks for that. I've managed to sort it. Turns out the drivers side footwells (front and rear) were full of water and the loom submerged causing a short to ground, fantastic these Range Rovers ! |
