![]() | Home > In Car Electronics > Hi from newbie |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
no need to connect it mate, bluetooth is similar to wireless. If the phone is paired with the bluetooth broadcast from your RRS(Land Rover) all you need to do is make a call and it should mute the stereo activate the microphone in the car.
Ticker Member Since: 05 Jan 2012 Location: Derbyshire Posts: 8 ![]() ![]() ![]() |
Hi,
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
You need an updated bluetooth module then,Wiggs is the man on disco3 he does an exchange unit.Its behind the carpet on the off side in the boot,2 or 3 screws 5 minute job it will pair automatically when you get in the car and your contacts will be displayed on the screen.I think they cost £60
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
IIRC the cradle you are talking about is only on pre 2009 models. It was only designed to fit Nokia phones and even then it was only a couple of models. |
