Home > In Car Electronics > Hi from newbie |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
no need to connect it mate, bluetooth is similar to wireless. If the phone is paired with the bluetooth broadcast from your RRS(Land Rover) all you need to do is make a call and it should mute the stereo activate the microphone in the car.
Fri Jan 06 2012 8:43am |
Ticker Member Since: 05 Jan 2012 Location: Derbyshire Posts: 8 |
Fri Jan 06 2012 6:21pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
You need an updated bluetooth module then,Wiggs is the man on disco3 he does an exchange unit.Its behind the carpet on the off side in the boot,2 or 3 screws 5 minute job it will pair automatically when you get in the car and your contacts will be displayed on the screen.I think they cost £60
Fri Jan 06 2012 10:44pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
IIRC the cradle you are talking about is only on pre 2009 models. It was only designed to fit Nokia phones and even then it was only a couple of models. As far as any modern phones or smart phones are concerned, forget it. They can't be plugged in and you will just have to make do with a blue tooth connection. Welcome to the quirky world that is the RRS 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Sat Jan 07 2012 10:32am |
