Home > General > dreaded power loss on the TDV8! |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
A turbo failed on my TDv8 at 4 years old and 78 thousand miles. LR picked up half the bill when I grumbled about it. I had to demonstrate that I was a life long LR buyer.
Tue Dec 06 2011 8:01am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
did you have a warranty? ============
Tue Dec 06 2011 8:54am |
jaz9443 Member Since: 19 Jul 2011 Location: London Posts: 38 |
Unfortunately no warranty which is a lession learned!
Tue Dec 06 2011 10:23am |
Hitman Member Since: 11 Nov 2011 Location: Scotland Posts: 27 |
When I got the engine managment light on my TDV6 which were found to be the AGR valves there was also aloss of power, might be them mate which are not that expensive |
Wed Dec 07 2011 4:16am |
Thanks Hit an, i'll be sure to mension this to the guys! RRS SDV6 PHEV Autobiography - MY2018 conversion
Wed Dec 07 2011 10:14am |
Hello - quick update, good news is that the turbo has not failed and that the actuator on the turbo had completely got stuck closed! They also checked the other one and found that one stuck on 25%!
Fri Dec 09 2011 6:22am |
Asil SAYAR Member Since: 08 Dec 2011 Location: Istanbul Posts: 5 |
Nice How did they fix actuators? Did they change actuator rods, which are available seperately from LR? One life, live it... |
Fri Dec 09 2011 6:34am |
I'll confirm later once I pick the car up and find out the exact details! RRS SDV6 PHEV Autobiography - MY2018 conversion
Fri Dec 09 2011 6:36am |
Hello, the fault code was P0249 and the acuators were stuck and taken apart cleaned and re assembled. The car drives very well with more power than before and can now here the V8 growl!
Sun Dec 11 2011 10:21pm |
