Home > General > dreaded power loss on the TDV8!
jaz9443
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Marmaris Teal
The loss of power and engine fault message is what greeted me this morning!
It goes in tomorrow for a confirmationturbo has gone byebye!
Looking forward to the bill...not!
[/quote] RRS SDV6 PHEV Autobiography - MY2018 conversion
Porsche 911 Turbo S PDK
BMW 335D Xdrive Touring
Post #324062 Mon Dec 05 2011 9:40pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
A turbo failed on my TDv8 at 4 years old and 78 thousand miles. LR picked up half the bill when I grumbled about it. I had to demonstrate that I was a life long LR buyer.
Make sure your vehicle is recovered to a workshop who knows what they are doing and have the correct body lift off ramp. My vehicle repair turned into a completely unnecessary wild goose chase around my engine. But once put back together she has run just fine for the last 10 thousand miles.
By the way - I got no error message and the turbo failure was sudden (when accelerating away from a junction) and the vehicle would not start again afterwards. So if yours has simply lost power and was driven home - I suspect you may be looking at something less than a wholescale turbo failure.
Hope all better soon and Christmas doesn't have to be cancelled Thumbs Up RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #324080 Tue Dec 06 2011 8:01am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
did you have a warranty? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #324085 Tue Dec 06 2011 8:54am
jaz9443
Unfortunately no warranty which is a lession learned!
The indy garage i'm using is investigating further, fault code is turbo related however they cannot discount if its a wastegate failure or even a splithose or pipe.
Its good to know they are not just assuming its a turbo failure, even revving engine to 4000 rpm and no smoke which they say is a good sign!
I'll update you guys hopefully in the next few days! RRS SDV6 PHEV Autobiography - MY2018 conversion
Post #324102 Tue Dec 06 2011 10:23am
Hitman
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Alaska White
When I got the engine managment light on my TDV6 which were found to be the AGR valves there was also aloss of power, might be them mate which are not that expensive
Post #324226 Wed Dec 07 2011 4:16am
jaz9443
Thanks Hit an, i'll be sure to mension this to the guys! RRS SDV6 PHEV Autobiography - MY2018 conversion
Post #324244 Wed Dec 07 2011 10:14am
jaz9443
Hello - quick update, good news is that the turbo has not failed and that the actuator on the turbo had completely got stuck closed! They also checked the other one and found that one stuck on 25%!
I pick the car up later today but his last words to me was the car is a rocket ship!
Needless to say I am very pleased its few hundred than few thousand, i'll be buying a warrenty asap!
I shall also post the fault code so if anyone else gets this issue they can let the garage know what to look for.
I do feel like going back to the first garage I went to a few days ago and giving them a bit of stick for telling me I needed a new turbo! RRS SDV6 PHEV Autobiography - MY2018 conversion
Post #324523 Fri Dec 09 2011 6:22am
Asil SAYAR
Turkey
Nice Very Happy How did they fix actuators? Did they change actuator rods, which are available seperately from LR? One life, live it...
Post #324524 Fri Dec 09 2011 6:34am
jaz9443
I'll confirm later once I pick the car up and find out the exact details! RRS SDV6 PHEV Autobiography - MY2018 conversion
Post #324525 Fri Dec 09 2011 6:36am
jaz9443
Hello, the fault code was P0249 and the acuators were stuck and taken apart cleaned and re assembled. The car drives very well with more power than before and can now here the V8 growl!
Very happy = next a warrenty! RRS SDV6 PHEV Autobiography - MY2018 conversion
Post #324785 Sun Dec 11 2011 10:21pm
