Home > General > Fuel Burning Heater |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Hi Muddy, mine is going in Wed to be activated on the screen but now considering getting the rest of the bits needed and going the whole hog and using the remote. Not sure if the parts required have changed or if the items above are still correct, don't want to buy the wrong bits MY16 AUTOBIOGRAPHY Indus silver with some toys
Mon Nov 18 2013 9:53am |
Hi Harry,
Mon Nov 18 2013 2:02pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Hi Rigsby, That sounds more up my street. I have two Indies near me, and i have someone who does Electronic diognostic work for many main stealers, he has thousands of pounds in software that mybe cover this operation.If not who is your Indy. I am down at Hayling Island in January. How long does it take
Mon Nov 18 2013 3:36pm |
Hi Harry,
Mon Nov 18 2013 3:43pm |
Superchargers don't have the park heat unit as standard...did you have it fitted? Mike 2014 Facelift Discovery Last edited by mse on Tue Nov 19 2013 1:09pm. Edited 1 time in total |
Mon Nov 18 2013 5:52pm |
Hi Mike My 10MY 3.0 TDV6 has the FBH already fitted. But was not enabled to be used as a Park Heater. There isn't any timer on the Sat Nav screen. I had the 2008 2.7TDV6 with FBH and was told that it could not be enabled without spending loads of dosh. But was told the 2010./ on 3.0 TDV6 could be activated,if the FBH was already fitted.
Tue Nov 19 2013 8:31am |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 |
If it not fitted as standard on the supercharge than no. Thought it might be like the rest. All you had to do was activate it. Ah well. MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
Tue Nov 19 2013 8:56am |
Hi Sweetafton, Seems as though MSE has different veiws on this subject. In 2011 he posted that if you had the hardware already fiitted. Then it was a software issue. And just needed the right software to be downloaded to activate the excisting hardware.Landrover would have activated this facility when ordering from new at a high price. Its like the old days when all models of a particular car shared the same wiring loom. And the higher spec model had the extras fitted and plugged in. It was cheaper to have one wiring loom than to have several different ones MSE makes sense if its there it just needs the no how to get it to work
Tue Nov 19 2013 9:30am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8999 |
Harry, the S/C didn't have the FBH as standard - it was an option that had to be specified at build. No doubt it's possible to retro-fit one but as it'll likely include all of the fuel piping etc. back to the tank, it's probably not a cheap job.
Tue Nov 19 2013 9:47am |
Hi RRSTDV8, My mind is focused on HSE Diesel. So that is where i am coming from. i have the FBH already fitted but require the software downloaded to operate and set the timer on sat nav screen.Harry itisme |
Tue Nov 19 2013 12:52pm |
Risgby - no problem mate
Tue Nov 19 2013 1:07pm |
MSE, maybe i didn't make myself clear. But what you have just said is what i was trying to say. I have the FBH already fitted I now need it activated to work on a timer set on the sat nav screen. Which facilty i haven't got. I have now found an Indy to do this for me in London, Booked in for next Tuesday. Sorry for any Confusion or upset i have caused
Tue Nov 19 2013 4:28pm |
Htailor23 Member Since: 01 Jan 2014 Location: London Posts: 7 |
I've just bought a RRS from LPR, and trying to find out how much the FPH costs to have activated. Also does it come with a Remote or is this extra.
Wed Jan 01 2014 2:09pm |
The timed climate (on screen) will need activating and if you want the remote then it's an aerial, a receiver and the remote fob. Have a search under "2012 timed climate" for more details MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Jan 01 2014 3:27pm |
