Home > General > Fuel Burning Heater
Page 2 of 12 <123 ... 101112>
Lookers Park Royal
All RRS diesels (well UK anyway) have a FBH which assists the engine in heating up quicker in cold climates (sub 4deg IIRC). The Remote Park Heating uses the FBH to pre-warm the cabin by remote. This has been an option for some time, and was made standard on diesel Autobiography when it was launched. Just to confuse things, Timed Climate was introduced on 12my which is similar to RPH however you set a timer via the Infotainment screen as opposed to using the remote.
With regards to smoke, personally I find that the first few times the FBH cuts in on a new vehicle it can produce a lot of smoke. The same can be said for an older car during the first FBH cycle due to old diesel being sat in the FBH fuel lines over the summer months.
James Thumbs Up
Last edited by Lookers Park Royal on Sat Nov 19 2011 10:09am. Edited 2 times in total
Post #321740 Sat Nov 19 2011 7:08am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
FBH operation
I have heard that the FBH is only there to assist the warm up of the engine. It operates when the engine is started, and warms the water so as to get engine temperature up quicker. The smoke at the front of the car is the exhaust of the heater,comes out front n/s wing. I have also heard that it can be converted to remote operation before engine start up. At about £200 Look at Webasto web site. Says it can be activated on a timer or from 1000 mtrs itisme
Post #321748 Sat Nov 19 2011 9:35am
You can get a few 3rd party systems that will get the FBH started without starting the engine. I had one fitted that started the FBH using a phone number - fantastic as I phoned the car up 20 minutes before I was due to go out on a cold morning and the car was nice and warm with all iced up windows cleared. Well worth the investment IMO. 2005 Zambezi TDV6 - Gone but not forgotten
Post #321749 Sat Nov 19 2011 9:51am
harrygh60
Hi,Very Annoyed, Have you got a contact number for the fitters that did this for you? I have tried to contact the engineers on the Webasto Site but none of them reply. Also as i bought my RRS used i dont know if it had a remote, and was kept by previous owner or lost.It must have a reciever to use a remote. itisme
Post #321753 Sat Nov 19 2011 10:05am
99% sure you will not have a remote as very few people fit these kits. Mine was a unit we bought as a group buy on this site but pretty sure site sponsors bellautos do something similar. 2005 Zambezi TDV6 - Gone but not forgotten
Post #321757 Sat Nov 19 2011 11:06am
Tonyrec
Thanks chaps for sorting this confusion Bow down Thumbs Up
Post #321768 Sat Nov 19 2011 1:04pm
mse
rrsboy wrote:
are the FBH and the Park Heater different things?
Yes and no
The Park heater is a software option to enable the option on the central screen and extra hardware for the remote
Uses the same hardware to generate the heat
Which works as the car decides to speed up heating if you dont have the enable park heat...which can be enabled Mike
2014 Facelift Discovery
Post #321878 Sun Nov 20 2011 7:09pm
Lookers Park Royal
Fuel Burning Heater (FBH) - Fitted to all Diesels to speed engine heat-up.
Remote Park Heating - Std on Autobiography Diesel and optional on others. Can activate the FBH before starting the car to heat the interior.
Timed Climate - As per RPH but instead of a remote you set a timer via the Nav screen. Std on 12my.
James Thumbs Up
Post #321881 Sun Nov 20 2011 7:19pm
rrsboy
on my 10 plate MY10 the RPH is insane! the range of the remote is amazing Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #321883 Sun Nov 20 2011 7:21pm
mse
James Thumbs Up
As mentioned - timed climate is software, remote is addition of hardware for the remote only and software and all use the base kit (hardware) for the FBH Thumbs Up Mike
Post #321889 Sun Nov 20 2011 7:52pm
Krx84
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
James Thumbs Up
Any body have the part numbers for the remote hardware? Install guide if possible? RRSport - 2010
Post #327770 Wed Jan 11 2012 10:23pm
JUCOTT01
You will ned to have the timed climate activated in order to use the remote (i think !!)
Just done mine today with an Autologic
www.disco4.com/forum/topic72204.html?highlight=TIMED+CLIMATE
This will give you what you need simple plug and play
Receiver £89.25 + vat
Antenna £17.83 + vat
Direct from landrover RRS MY11 BALI BLUE OVERFINCH
Post #327771 Wed Jan 11 2012 10:32pm
Krx84
What about the key fob cost? Any chance for part numbers?? Help appreciated...my mate is an auto technic so im confident he must have the autologic...did you fit the remote aswell? RRSport - 2010
Post #327776 Wed Jan 11 2012 11:05pm
JUCOTT01
Just going to order it from land rover tomorrow will get a remote from them as well
Have enabled park heater with the autologic so we will see if the remote function operates when i stick it in
Did you have a look at the thread on the D4 site ??
LLR008656 Reciever
LLR008654 Antenna RRS MY11 BALI BLUE OVERFINCH
Post #327777 Wed Jan 11 2012 11:11pm
Krx84
Yes had a look, but i thought the parts would be diifeent in a disco...i hope i can find someone to activate the option soon...im from lancashire or else id be coming to you first thing in morning!! RRSport - 2010
Post #327784 Wed Jan 11 2012 11:32pm
