Home > Technical > "Suspension will raise once system cooled"
m14rsh
I received this message on the drivers display yesterday whilst pulling away after having it in access suspension mode:
So I gave it over night to 'cool down' and have started and driven this morning but suspension still in 'access' mode and the 4x4 info screen says "raising".
What is wrong and what to do????
Many thaks in advance, Martin 2014 RRS
Post #321134 Mon Nov 14 2011 3:32pm
u might need a new compressor Big Cry RRS gone
Post #321236 Tue Nov 15 2011 9:58am
m14rsh
Got in today and turned engine on, height button lights illuminated were the up arrow and the off road height setting aswell as the middle setting, the 4x4 info screen said access level.
I let the car run for a bit and then pressed the up arrow, the message on the drivers display read
"vehicle raising slowly"
After about a minute the 4x4 info screen said standard and the buttons went back to normal, the car had risen to standard height and all has been fine today, I haven't attempted to lower it again though.
Any ideas??? 2014 RRS
Post #321291 Tue Nov 15 2011 6:10pm
ELD70
Still sounds like compressor on the way out to me......
Post #321358 Tue Nov 15 2011 11:10pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
You may have a problem (puncture) with one of the air bag suspension units which has been causing the compressor to work overtime to keep the car level. Over time, this can cause the pump to burn-out due to overheating. I has this problem with my old disco 2 and had to replace a suspension airbag as well as the compressor..
Cheers,
J
Post #321369 Wed Nov 16 2011 6:07am
Supacat
As Jmac says - the compressor is only rated for intermittant use rather than constant duty and so if it's working too hard it will get hot and there's a thermal cut-off switch built in to protect the equipment.
Post #321512 Thu Nov 17 2011 8:12am
DrLex
Iceland
It is also not unknown for the compressor relay to stick, thereby running the compressor needlessly. As noted above, extended use will result in premature failure of the unit.
Post #321521 Thu Nov 17 2011 8:41am
rangehelper
Russia
The experience of this fault air suspension compressor (possibly: dryer, silencer) At a given fault changing the compressor with a silencer. Check the muffler can be by turning off the inlet tube (inlet air to compressor). Often become worthless dryer. The forum Discovery 3 describes the procedures for "witchcraft" of the compressor.
Post #321564 Thu Nov 17 2011 2:31pm
