Home > Technical > "Suspension will raise once system cooled" |
m14rsh Member Since: 26 Sep 2010 Location: Norwich Posts: 97 |
I received this message on the drivers display yesterday whilst pulling away after having it in access suspension mode:
Mon Nov 14 2011 3:32pm |
u might need a new compressor RRS gone
Tue Nov 15 2011 9:58am |
Got in today and turned engine on, height button lights illuminated were the up arrow and the off road height setting aswell as the middle setting, the 4x4 info screen said access level.
Tue Nov 15 2011 6:10pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Still sounds like compressor on the way out to me...... |
Tue Nov 15 2011 11:10pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
As Jmac says - the compressor is only rated for intermittant use rather than constant duty and so if it's working too hard it will get hot and there's a thermal cut-off switch built in to protect the equipment. |
Thu Nov 17 2011 8:12am |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
It is also not unknown for the compressor relay to stick, thereby running the compressor needlessly. As noted above, extended use will result in premature failure of the unit. |
Thu Nov 17 2011 8:41am |
rangehelper Member Since: 17 Nov 2011 Location: Moscow Posts: 4 |
The experience of this fault air suspension compressor (possibly: dryer, silencer) At a given fault changing the compressor with a silencer. Check the muffler can be by turning off the inlet tube (inlet air to compressor). Often become worthless dryer. The forum Discovery 3 describes the procedures for "witchcraft" of the compressor. |
Thu Nov 17 2011 2:31pm |
