Home > General > Off Road tyres
flydive
Off Road tyres
I will soon receive some 18" wheels for my RRS
As they will be mostly(I would say strictly) used off road for fun I would like to install some off road oriented tyres.
I was looking at the following
Goodyear new MT/R(if/when available again)
Cooper ST or STT
Hankook Dynapro MT(if I can find them) heard some good about them
Size wise they are available only in a slightly taller size, 275/65 18, but that should not be a problem, especially with the LLAMS module
You guys have any idea/suggestion/experience?
Thank you '08 RRS TDV8
Post #312081 Wed Aug 31 2011 3:50pm
Will 18" wheels fit your RRS if its as your avatar a TDV8 Question Hasn't it got brembo brakes Question If so then 18's won't fit Banging Head
Post #312085 Wed Aug 31 2011 4:28pm
flydive
Yes it is a TDV8 and it has Brembo brakes, but the wheels are the Compomotive P1880, so they will fit Wink '08 RRS TDV8
Post #312086 Wed Aug 31 2011 4:44pm
Shocked Thumbs Up
Post #312101 Wed Aug 31 2011 7:15pm
Roland
Switzerland
Flydive Very Happy ,
I have also ordered a set of five PD1880 in black and should receive them soon Thumbs Up Thumbs Up They were sold out and Compomotive did a new batch at the end of August.
Looks as if they'll organsie a bulk shipment to Switzerland...
My plan is to fit the new General Grabber ATs, since Goodyear has no plans continuing their previous MT/R in 19 or 18 inch size. Their new Kevlar MT/R will only be available in 16 inch or smaller. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #312155 Thu Sep 01 2011 6:17am
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
Here you go,they are not the Dynapro but they are Hankook.
http://www.camskill.co.uk/m65b0s3200p21597...T_123Q_TL_
Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #312158 Thu Sep 01 2011 8:18am
flydive
Yes, getting them from the same batch, ordered them together with a D4 owner here in Ticino, too bad we did not know about you, we could have saved a couple of GBP
Yes that could also be an option
Andy.
They look like the one I was talking about, probably different name for different markets(saw them in a US magazine) '08 RRS TDV8
Post #312199 Thu Sep 01 2011 3:04pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
Re: Off Road tyres
Thank you
I have the same size in the Maxxis Bighorns for my off-road wheels. The size is quite a fair bit taller than the std tyre and requires more than just a LLAMS module or shortened HS rods to use effectively. Essentially you have to:
* cut back the inside of the lower front lip to stop the front tyre hitting it when turning
* cut out and discard the front half of the rear wheel-well liner
* bend back the metal seam that will now be exposed in the rear wheel-well
You'll still get slight rubbing at full articulation (even at +50mm) and the occasional suspension fault that will require cycling the ignition.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #312261 Fri Sep 02 2011 1:23am
flydive
Thanks for the info Gordon, looks a bit of work, not sure I want to go all that way, I will not be off roading often, just few days of fun from time to time.
I might have to go for a less off road tyre with closer size to the standard.
Too bad. '08 RRS TDV8
Post #312291 Fri Sep 02 2011 2:25pm
disco4x4au
Yokohama's AT/S comes in a 275/60R18 and is pretty aggressive for an AT tyre. Cooper's new AT3 is close to a muddy as well, and they're releasing a few new sizes in 18" in the coming months. The current Cooper Zeon LTZ (in 285/60R18) is also worth considering.
Cheers,
Post #312540 Mon Sep 05 2011 2:00am
flydive
Thanks, I will look into that, not in a hurry anyway at the moment I'm away to work few thousands miles from my RRS, and will be for a while, so no much off roading coming up soon Crying or Very sad '08 RRS TDV8
Post #312566 Mon Sep 05 2011 9:10am
