![]() | Home > General > Off Road tyres |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I will soon receive some 18" wheels for my RRS
Yes it is a TDV8 and it has Brembo brakes, but the wheels are the Compomotive P1880, so they will fit |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 ![]() ![]() |
Flydive ![]() I have also ordered a set of five PD1880 in black and should receive them soon ![]() ![]() Looks as if they'll organsie a bulk shipment to Switzerland... My plan is to fit the new General Grabber ATs, since Goodyear has no plans continuing their previous MT/R in 19 or 18 inch size. Their new Kevlar MT/R will only be available in 16 inch or smaller. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
Here you go,they are not the Dynapro but they are Hankook.
Yes, getting them from the same batch, ordered them together with a D4 owner here in Ticino, too bad we did not know about you, we could have saved a couple of GBP
Yes that could also be an option
They look like the one I was talking about, probably different name for different markets(saw them in a US magazine) '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
I have the same size in the Maxxis Bighorns for my off-road wheels. The size is quite a fair bit taller than the std tyre and requires more than just a LLAMS module or shortened HS rods to use effectively. Essentially you have to: * cut back the inside of the lower front lip to stop the front tyre hitting it when turning * cut out and discard the front half of the rear wheel-well liner * bend back the metal seam that will now be exposed in the rear wheel-well You'll still get slight rubbing at full articulation (even at +50mm) and the occasional suspension fault that will require cycling the ignition. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Thanks for the info Gordon, looks a bit of work, not sure I want to go all that way, I will not be off roading often, just few days of fun from time to time.
Yokohama's AT/S comes in a 275/60R18 and is pretty aggressive for an AT tyre. Cooper's new AT3 is close to a muddy as well, and they're releasing a few new sizes in 18" in the coming months. The current Cooper Zeon LTZ (in 285/60R18) is also worth considering.
Thanks, I will look into that, not in a hurry anyway at the moment I'm away to work few thousands miles from my RRS, and will be for a while, so no much off roading coming up soon |
