Home > General > Problem with MY11 TDV6 HSE - Help? |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
i'd be grateful if you can tell us why you left foot brake in an automatic 3 tonne 4x4! ============
Thu Jul 07 2011 10:04pm |
Leapy Member Since: 02 Jul 2011 Location: Sheepy Parva Posts: 10 |
Two feet, two pedals. Simples Weight and drive configuration aren't factors... 2011 RRS HSE 3.0V6 2011 Freelander HSE 2.2d Auto Gone...2010 RRS V8 HSE |
Fri Jul 08 2011 5:35am |
Fri Jul 08 2011 7:52am |
In the context of this post 2011 RRS HSE 3.0V6 2011 Freelander HSE 2.2d Auto Gone...2010 RRS V8 HSE |
Fri Jul 08 2011 8:01am |
kentwales Member Since: 22 Jun 2011 Location: Kent Posts: 5 |
800 wonderful miles into my MY11 TDV6 HSE I had a similar experience on the M6 yesterday. Lost acceleration intermittently for an hour, engine system warning on dash. I think it was happening at two gearchage points - from 5 to 6 at about 65mph and from 3 to 4 at about 30mph. Engine didn't cut out, just disengaged throttle and slowly lost speed.
Mon Jul 11 2011 6:17am |
santorini Member Since: 07 May 2011 Location: England Posts: 26 |
Had the car in, dealer said there was a technical bulletin regards this from landrover and made adjustment to brake pedal.... Only driven home from dealer yet so can't confirm whether it's fixed for good or not. |
Wed Jul 13 2011 9:11pm |
andaval Member Since: 23 Apr 2011 Location: London Posts: 9 |
Did you find the fix cured the issue? I seem to have a mild form of the issue when it changes up from 1st to 2nd where it's quite a sluggish change. The dealer thinks it might be a software issue, so here's hoping Once it gets going, it seems fine. |
Wed Jul 27 2011 9:39pm |
So far so good, not had the problem the last 600 miles or so |
Wed Jul 27 2011 10:53pm |
bellcrank Member Since: 19 Jan 2015 Location: Kent Posts: 11 |
My first post here, by way of introduction I acquired my first RRS, a MY11 with approx 45,000 miles on the clock about a month ago and have covered around 1,500 miles. Yesterday I had exactly the same experience as the OP in this thread. I had just pulled onto a large, busy roundabout too, very scary. Did anyone find a fix or solution for this? Any help would be appreciated |
Mon Feb 16 2015 8:30am |
