Home > General > Problem with MY11 TDV6 HSE - Help? |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 |
Have you played with the terrain settings? Mine used to don then when i used to comeout of using the snow mode....and it would not go anywhere when I put my foot down...and yes you're right, it's very scary....
Wed Jul 06 2011 1:05pm |
Battery terminals loose??? Foxy's 11 plate were loose also ive heard a few other have been loose too. |
Wed Jul 06 2011 1:10pm |
santorini Member Since: 07 May 2011 Location: England Posts: 26 |
Would loose terminals cause that though? When I say the car 'dies' the engine doesn't stop and the electrics all stay on, it's just like the car has no drive. It's not in neutral because the car won't rev, the car just sits there even though you have half throttle. It then suddenly wakes up and you take off.... |
Wed Jul 06 2011 1:14pm |
I haven't used any modes apart from normal or dynamic. But yesterday I hadn't used either since the start of the journey and it did this about 3 miles into the journey.... And twice on the way home..... |
Wed Jul 06 2011 1:16pm |
Mate just call LR assistance before it goes in, best to know what's happening and the LR assist guys can help. When you call, check they are sending a LR technician and not anyone else.... |
Wed Jul 06 2011 1:19pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Get it to a dealership (or looked at by LA) asap... just a matter of time before it stops totally and you'll be sat on the roadside waiting for a low loader!
Wed Jul 06 2011 1:21pm |
A bad earth might, i'm only guessing really, LR will probably say its down to some dodgy fuel. As said above let the professionals sort it out |
Wed Jul 06 2011 2:05pm |
I'll wait a couple of days until it goes to the local dealership. Can't see the point in calling assistance as the car only does it say 1 time out of 100 or more....
Wed Jul 06 2011 2:17pm |
SilverspeedRRS Member Since: 29 Jun 2007 Location: Leicestershire Posts: 95 |
Turbo lag ? On order Corris Grey New HSE 5+2 with Santorini contrast roof , ebony/cirrus interior and panoramic roof. |
Wed Jul 06 2011 2:18pm |
It's only had BP ultimate diesel so not dodgy fuel if they blame that! |
Definetely not turbo lag! |
Wed Jul 06 2011 3:19pm |
webb Member Since: 06 Jun 2011 Location: uk Posts: 43 |
Probably a simple fix, but just let your dealer sort it out.
Wed Jul 06 2011 4:57pm |
Leapy Member Since: 02 Jul 2011 Location: Sheepy Parva Posts: 10 |
The engine management is configured such that power is restricted if the brakes are anything other than completely off. Do you left foot brake by any chance? I do, and I've run into this. Any chance you might just be tickling the brake pedal whilst opening the throttle? Even if it's with your size 12 right boot? 2011 RRS HSE 3.0V6 2011 Freelander HSE 2.2d Auto Gone...2010 RRS V8 HSE |
Thu Jul 07 2011 3:33pm |
Pretty sure I'm not doing that. But you've got me thinking perhaps it's something to do with sensors on the accelerator or brake pedal, whereas I originally thought it was to do with gearbox. I suppose I'll find out when at the dealer, I just hope I don't get the 'we can't replicate the fault sir' answer as the car isn't really safe to drive like this.... |
Thu Jul 07 2011 6:13pm |
