![]() | Home > Technical > Range Rover Sport Suspension Fault, Code C1A00 |
Bobby is the man that will know the answer |
stuartw1974 Member Since: 27 Jun 2011 Location: England Posts: 3 ![]() ![]() |
Thanks.
Your fault code is incomplete.
Thanks I'll have this looked at.
Don't jump the gun. It is not necessary the module is kaput.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Stuart,
dhenz70 Member Since: 08 Aug 2011 Location: gulf states Posts: 4 ![]() |
that is C1A00-47,your EAS pump faulty |
Problem sorted - new suspension compressor fitted myself. PM me if any help needed. 16MY Estoril Blue SVR.............
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
i have just got the same fault with red light on and it wont go off code is c1a00-52-arcm any help please |
Imy Member Since: 08 Nov 2015 Location: Birmingham Posts: 3 ![]() ![]() ![]() |
Hi I have code c1a20......wanted to know if I need to change compressor or drier |
Hoppa1950 Member Since: 23 Jan 2016 Location: Durham Posts: 10 ![]() ![]() ![]() |
I changed the drier kit on my compressor and the car worked fine for about 20 mins and then started the same problem spend ion fault.
