Home > Technical > Range Rover Sport Suspension Fault, Code C1A00
stuartw1974
2006 Range Rover Sport TDV6 HSE Java Black
Great Site Guys!
Hi all sorry if this question has been addresssed before I am new to this site and havent been able to find my answer.
I have a 2006 Range Rover Sport, 2.7tdv6.
Today the Dynamic Driving Warning light came on whilst doing 30mph on tarmac, the amber light, (Wobely land rover light) after I went over 60mph it went red and stated max speed 30mph.
It doesnt reset when I cycle the igntion.
Does anybody know what causesd this.
I have borrowed a friends Launch x431 Scan tool and under the menu Ride Level Control Module, Its coming up only with Fault code C1A00 Control Module.
Other control modules are also reporting less of communication with the same control module.
The vehicle seems to be stuck in highway mode.
The nav 4x4 screen states highways mode and the right hand side of the screen with the 4 wheels show nothing but the 4 wheesls.
Anybody able to help me out with my problem.
Thanks guys in advance..
Stu
Post #304161 Mon Jun 27 2011 7:32pm
Bobby is the man that will know the answer Thumbs Up
Post #304182 Mon Jun 27 2011 8:52pm
stuartw1974
Thanks.
How do I get hold of him?
Post #304188 Mon Jun 27 2011 9:01pm
Bobby
Your fault code is incomplete.
There are additional number(s) and/or alphabets at the end, however, they all point to some problems/faults with the Vehicle Dynamic Suspension Control Module.
I would suggest using a proper LR Diagnostic Tool to help. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #304208 Tue Jun 28 2011 2:16am
stuartw1974
Thanks I'll have this looked at.
Is the module coded?
Can I buy a 2nd hand one and fit that?
Do you know where the module is located?
Post #304219 Tue Jun 28 2011 6:33am
Bobby
Don't jump the gun. It is not necessary the module is kaput.
There could be other reasons like battery low voltage, control valve short circuit, water ingress etc.
Best to let a proper LR technician to look at it with a diagnostic tool. Malaysia Boleh!
Post #304255 Tue Jun 28 2011 11:06am
PEACHY
Suspension Problems.
Stuart,
Did you get this sorted - going through exactly the same problem now. Big Cry 16MY Estoril Blue SVR.............
Post #314635 Thu Sep 22 2011 6:05am
dhenz70
that is C1A00-47,your EAS pump faulty Big Cry
Post #317017 Tue Oct 11 2011 3:13pm
PEACHY
Problem sorted - new suspension compressor fitted myself. PM me if any help needed. 16MY Estoril Blue SVR.............
Post #317066 Tue Oct 11 2011 7:38pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i have just got the same fault with red light on and it wont go off code is c1a00-52-arcm any help please
Post #390651 Thu Aug 01 2013 8:06pm
Imy
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Hi I have code c1a20......wanted to know if I need to change compressor or drier
Post #479171 Sun Nov 08 2015 10:20pm
Hoppa1950
United Kingdom 2013 Range Rover Sport SDV6 HST Firenze Red
C1A00
I changed the drier kit on my compressor and the car worked fine for about 20 mins and then started the same problem spend ion fault.
I then changed the the compressor and all wax ok fir about threedays and then all the lights and faults came on in red and would not allow me to drive any faster than 30mph.
The fault all along was a alternator because I changed the battery at the she time as the compressor the cafe had been running in the battery power and this wasalso cooked because of th alternator.
Have your alternator checked out first.
Post #485558 Sat Jan 23 2016 5:57pm
