Home > General > Storing wheels and tyres.
Page 4 of 4 <1234
SRE
Spain
This is how to protect & store your tyres + keeps them out of the sun. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #299012 Wed May 11 2011 9:35am
DSL
In my dreams!!! Mr. Green
Post #299037 Wed May 11 2011 11:51am
Bradders
Rolling with laughter Rolling with laughter Rolling with laughter FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #299042 Wed May 11 2011 11:53am
drdelrrs
'Tread' carefully they look like wet weather equipment.
Post #299093 Wed May 11 2011 4:30pm
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I bet its not the only rubber they ride on daily i mean sit on ! ! Whistle Smile
Post #299097 Wed May 11 2011 4:39pm
SRE
Spain
I said you were a wild child
Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #299102 Wed May 11 2011 5:05pm
0cj0
DSL wrote:
You'll need a decent sized boot for wheel & tyre collecting, not your teeny weeny RRS one!! There are advantages to driving a Pikeymobile, you can get 10 in there with all the seats down! Whistle
Laughing My tyre/wheel collecting fetish seems to take a long time these days Whistle
Post #299104 Wed May 11 2011 5:11pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
R Tord Gert says she has a spare tyre she wants rid of Whistle
Post #299107 Wed May 11 2011 5:29pm
DSL
Re Smart: Rolling with laughter Rolling with laughter Thumbs Up
Post #299109 Wed May 11 2011 5:41pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
i've just remembered I once flew in a helicopter too ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #299120 Wed May 11 2011 7:34pm
leedsunited
Dont start again, we have just got them to play nicely Laughing
Post #299122 Wed May 11 2011 7:38pm
rrsboy
i apologise! Smile ============
Post #299123 Wed May 11 2011 7:41pm
DSL
Spoilsport!! Rolling with laughter Rolling with laughter
Post #299127 Wed May 11 2011 7:50pm
paulgato
OK, I'm storing a set of winter wheels for the first time so I've been trawling the internet on this subject, and using my brain a bit too. Here's my conclusion...
All tyre manufacturers I've come across say to store tyres away from direct daylight, solvents and heat sources. They say that tyres on rims should be properly inflated and laid flat (or hung up) and tyres without rims should be stored vertically, on their treads, but should be rotated every few weeks.
That's all well and groovy, but why? In the case of tyres on rims I have not been able to find any reason for laying them horizontally other than to avoid getting flat spots. Tyres on vehicles laid up for the winter should also be lifted off the ground for this reason. This is old folk wisdom.
Applying a bit (a little bit) of my enormous brain, I have concluded the following:
Stored for a few months, it is extremely unlikely that a properly inflated tyre will develop a flat spot unless it is attached to a car at the time. Compared to the stresses a tyre suffers when it is having to support a vehicle, when it is off the vehicle those stresses are almost nil. There is no visible bulge at the bottom as there is when it is on the vehicle.
HOWEVER, ...if you come to fit your winter or summer tyres and find one of them has lost all its pressure and gone flat, then that tyre may well be permanently damaged, whereas if it had been stored horizontally then you'd probably get away with it as it will not have distorted under its own weight in the same way.
So, as I don't have a place I can easily store them layed down flat, I shall store them vertically and not worry, but I will put an extra bit of presure in them and check those pressures from time to time over the summer. While checking the pressures I can also rotate the wheels. It's easy enough to put a note in my diary to do that five-minute chore once a month.
I'm a cautious kind of person when it comes to these things and I feel very comfortable with my compromise.
Thanks everyone for all the thoughts on the subject.
Post #383078 Tue May 14 2013 6:38pm
Page 4 of 4 <1234
