Home > General > Fault Displayed on Dash Any ideas? |
It probably means a trip to your local dealer is imminent, |
Mon May 02 2011 6:00pm |
GTSteve Member Since: 20 Dec 2010 Location: northamptonshire Posts: 38 |
I will be calling the dealers 1st thing tommorrow , just so glad now I took out an extended Warranty last month otherwise I would be off with myself. I am just wondering any chance it could be the EGR valves? BLACK RRS HST 3.6 MY08 |
Mon May 02 2011 6:27pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
More than likely the egrs, RRS gone
Mon May 02 2011 8:20pm |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
Indeed Vadim A. |
Mon May 02 2011 9:35pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Normally a reboot of the car resolves, probably just an electrical gremlin. Unless it stays put, I would not worry about it.
Tue May 03 2011 10:12pm |
Just had a call from Stratones as I left my RRS with them to sort the problem out, and have been told that the fault codes show that there is a problem with the Rear Differential to make things worse they said that they have not come accross this fault before on an RRS so have sent the report to LR head office to get some advice as they dont want to change parts just for the sake of it! Has anyone had or heard of this problem before on this site? As I am not a mechanical person i asked what the diffential did and was informed that it distributes equal torque to the wheels for those of you that also didnt know. BLACK RRS HST 3.6 MY08 |
Fri May 06 2011 11:26am |
What with stratstones not knowing what to do? Yes! Hope your car is sorted Mike 2014 Facelift Discovery |
Fri May 06 2011 2:46pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
Yes, I had a rear diff problem on my 2008. Dealer didn't know what to do. Ended up getting another RRS instead of messing around with changing diffs. |
Fri May 06 2011 3:18pm |
Finally after my RRS has spent 7 days with Stratsones I collected it with the power problem solved! the fault was the (Power Flow Meter) on the right hand side of the engine, Not the Rear Diff as was earlier diagnosed in the week I cant believe they they have had the car a whole week for a 2 hour job, what annoys me is i have had to hire a car to get me around and at the moment I have had to fork out for the bill. I took out an extended warranty in march, which is Stratsones own through a company called Abraxas which I was advised to do by their warranty sales manager as it was £100 cheaper than the LR warranty but everything was the same other than the maximum single claim can not exceed £6000 so i took his advice. The repair work is covered under the warranty but as the labour was under 8 hours i dont quallify for a hire vehicle. The manager of strastones is supposed to be calling me back on Monday to discuss this issue but as I said to the guy who gave me back the keys its not my problem you were unable to diagnose the problem and you should be liable for the hire car. Can someone tell me if I had purchased a LR warranty would i have been given a hire vehicle regardless of labour time? BLACK RRS HST 3.6 MY08 |
Thu May 12 2011 9:10pm |
