![]() | Home > General > Fault Displayed on Dash Any ideas? |
It probably means a trip to your local dealer is imminent, |
GTSteve Member Since: 20 Dec 2010 Location: northamptonshire Posts: 38 ![]() ![]() ![]() |
I will be calling the dealers 1st thing tommorrow |
More than likely the egrs, RRS gone
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Indeed Vadim A. |
Normally a reboot of the car resolves, probably just an electrical gremlin. Unless it stays put, I would not worry about it.
Just had a call from Stratones as I left my RRS with them to sort the problem out, and have been told that the fault codes show that there is a problem with the Rear Differential |
What with stratstones not knowing what to do? Yes! Hope your car is sorted Mike 2014 Facelift Discovery |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Yes, I had a rear diff problem on my 2008. Dealer didn't know what to do. Ended up getting another RRS instead of messing around with changing diffs. |
Finally after my RRS has spent 7 days with Stratsones I collected it with the power problem solved! the fault was the (Power Flow Meter) on the right hand side of the engine, Not the Rear Diff as was earlier diagnosed in the week |
